[OpenLayers-Dev] Using GMAPS and own datasets
Maurizio Latini m.latini at geographike.it
Mon Jan 26 10:54:35 EST 2009
Good evening,
I'm trying to use GMaps as base layers together with some vector data
with ED1950 Zone 33N projection,
using MapSever as WMS generator. The final product is that between the
base layer (google satellite) and my own data there is a shift of
several meters between the two layers.
For Google I've used the epsg 900913 from the tutorial that I've found
on the wiki, and for my data I've made a map file with the PROJECTION
element epsg:900913 and the
layer projection epsg:23033.
Is there something that I'm missing?
Thanks,
Maurizio
More information about the Dev mailing list
