[OpenLayers-Dev] hidden but selectable features
Pierre GIRAUD
bluecarto at gmail.com
Tue Jan 27 09:32:16 EST 2009
Hi all,
Here's a project use case : I have features in a vector layer in a map
and corresponding rows in an Ext grid. I want some of those features
to be hidden on the map. However, I want them all to be selectable in
the grid.
If a feature is selected in the grid, I want it to be shown as
selected on the map too, even it is was previously hidden.
In order to achieve this, I took advantage of the styleMap
uniquevaluerules and a specific lookup omitting the values for the
hidden features.
It was working well until r8620 [1]. The features are still hidden,
but selecting them programmatically has no effect.
I could have used lookup properties with empty style definition, but
hidden features are then selectable on the map, which I don't want.
I put some code (enclosed) to reproduce if someone wants to give it a look.
Help appreciated.
Regards,
Pierre
[1] http://trac.openlayers.org/changeset/8620
function init(){
map = new OpenLayers.Map('map', {maxResolution:'auto'});
var wms = new OpenLayers.Layer.WMS( "OpenLayers WMS",
"http://labs.metacarta.com/wms/vmap0", {layers: 'basic'} );
map.addLayer(wms);
map.setCenter(new OpenLayers.LonLat(0, 0), 0);
var styleMap = new OpenLayers.StyleMap();
// create a lookup table with different symbolizers for
the different
// state values
var lookup = {
'shown': {fillColor: "green"}
styleMap.addUniqueValueRules("default", "visibility", lookup);
layer = new OpenLayers.Layer.Vector('Points', {
styleMap: styleMap
map.addLayer(layer);
var feature = new OpenLayers.Feature.Vector(
new OpenLayers.Geometry.Point(0, 0),
{visibility: 'shown'}
layer.addFeatures([feature]);
new OpenLayers.Geometry.Point(0, 10),
{visibility: 'hidden'}
selectControl = new OpenLayers.Control.SelectFeature(layer);
map.addControl(selectControl);
selectControl.select(layer.features[0]);
selectControl.select(layer.features[1]);
More information about the Dev
