[OpenLayers-Dev] DeleteFeature control
Eric Lemoine
eric.lemoine at camptocamp.com
Tue Jul 21 14:20:16 EDT 2009
On Tuesday, July 21, 2009, Alexandre Dube <adube at mapgears.com> wrote:
> Hi,
> I'm trying to reproduce what we discuss. I'm not really familiar with this method and I'm having difficulties with 'this'. Here's what I have so far :
> /*** START ***/
> var delCtrl = new OpenLayers.Control({
> layer: olWFSRoads,
> handlers: {"keyboard": new
either use "handler" or give "handlers" an array
OpenLayers.Handler.Keyboard(this,{ // <------- 'this' is not the control
indeed, it's not the control, it is the current scope/object. Here
it's the object that's building the control, it may be "window" if
you're not creating the control from a specific object
> keydown: function(evt) {
> var code = evt.keyCode;
> //var features = this.layer.selectedFeatures; // <------- this is not the control, and so on...
yet another context, "this" refers to the keyboard handler here
("keydown" is a method of the keyboard handler)
> var features = olWFSRoads.selectedFeatures; // <----- can we avoid the use of olWFSRoads ?
I'm not sure whethet you can give handlers a specific scope for
executing callbacks. I don't think so.
> if(code == OpenLayers.Event.KEY_DELETE && features.length > 0 &&
> this.confirmDelete() ) {
> this.deleteFeatures(features);
> return;
> controls: [
> new OpenLayers.Control.SelectFeature(
> olWFSRoads, {
> onSelect: function(f) {
> f.state = OpenLayers.State.DELETE;
> this.layer.drawFeature(f);
> confirmDelete: function() {
> return (confirm("Delete selected features ?"))
> deleteFeatures: function(features) {
> this.layer.destroyFeatures(features);
> /*** END ***/
> I made the discussed changes to the OL.Control to be able to automatize activation/deactivation/setMap.
> If you look at the <---------- arrow, you'll see a 'this', which is supposed to be the control, owner of the handler. Well, that 'this' is not the control, it's the html page (figures). I tried to put 'delCtrl' instead but it didn't work. I really wonder how I am supposed to create controls that way (without creating a class) and use the 'this' (or something else).
> Any hint would be greatly appreciated,
> Alexandre
> P.S. Also, I believe it's ok to have my 'user' functions, like confirmDelete directly inside the control since the control is completely custom-made (i.e. not using events).
> Alexandre Dube wrote:
> Eric Lemoine wrote:
> so, to get to the delete control you've been working on, I see more
> value, in terms of flexibility, in adding "control composition" to the
> control base class.
> I also agree. Originally, the control had a Feature handler instead of a SelectFeature control. Looking at it now, it's too simple to be justified as a new control.
> About the 'controls' property and the act./dea. automatism : that's a good idea, but wouldn't it be good to have a 'handlers' property also and activate/deactivate all handlers as well ? Currently, control has a 'handler' property only. Would it make sense to have 'handlers' added a do the same kind of automatism as the new 'controls' property ?
> Agreed.
> Great.
> Alexandre Dubé
> Mapgears
> www.mapgears.com
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev
