[OpenLayers-Dev] handler style
Alexandre Dube
adube at mapgears.com
Thu Jul 23 08:05:57 EDT 2009
jessisena wrote:
> Hi,
> Anybody knows if is possible to have two differents controls Draw feature,
> with the same kind of handler (for example point), and everyone with their
> own style?
> That is, if I can have two controls that draw points with different styles,
> in the same layer.
> Thanks
You could overwrite the activate and deactivate function of both your
DrawFeatures control to add a "featureadded" listener to your layer. On
"activate", register the event. On "deactivate", unregister the event.
Both events could call a different function to add an attribute to the
added feature, let's say "type", the first control adds "1" as a value,
the second "2", then you would need to redraw the feature.
With all this, you could have a addUniqueValueRules to your layer's
styleMap object to render your features differently, based on your
"type" attribute.
Does this make sense ?
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev
