[OpenLayers-Dev] Request for help from Opera users
Tim Schaub tschaub at opengeo.org
Wed Jun 10 18:19:37 EDT 2009
Hey-
Roald de Wit wrote:
> Hi Tim,
> Tim Schaub wrote:
>> I'd like to get confirmation from someone with an older version of
>> Opera about what works and what doesn't.  My recollection is that the
>> patch made Opera 9.27 happy - even though it didn't remove all literal
>> regular expressions.  You'll note that we had literal regexes in
>> literal objects in 2.7 as well.  Hence my request for someone to check
>> 2.7 in the same version of Opera.
>> If nobody has Opera 9.27, I'll look at reverting mine.  Though this
>> does add weight to the opinion that the effort is a bit quixotic.
> Andreas pointed out that the problem with this Opera lies in the greedy
> parameter that's used in tokenRegEx ('g'). A quick search pointed me to
> over 40 cases in the OL library where we use the greedy parameter in
> When I played with Opera 9.27 yesterday, I could make the JS errors go
> away (in the sundials example) with changing the 'trim' function to use
> 'new RegExp' too.
> So, we *can* make some functionality work for this version of Opera if
> we put the effort in.
> The main question is: do we want to put all this effort in to support
> this version? I just asked the reporter of #2120 if he would consider
> upgrading to the latest Opera version [2], which might be the easiest
> way out.
The first question is: did these issues exist in 2.7?  If OpenLayers 2.7
did not work in Opera 9.27, then we are not talking about a regression.
Tim
> Older versions of Opera can be found here: [1] for anyone to try out.
> [1] http://www.filehippo.com/download_opera/3976/
> [2] http://trac.openlayers.org/ticket/2120#comment:7
> Regards, Roald
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev mailing list
