[OpenLayers-Dev] createLiteral enhancement proposal
Paul Spencer
pspencer at dmsolutions.ca
Fri Jun 19 11:14:23 EDT 2009
In the context of calling functions to compute styles for features
using the ${functionName} syntax, it would be very useful for me if
the property being computed was passed to functionName() in addition
to the feature itself. I've tested this locally by modifying
createLiterals to pass an array with [feature,i] (where i is the
property name) and createLiteral to replace feature with args, which
is passed to String.format as the third value. This works perfectly
for me. The only other use of createLiteral is in Rule, which does
not use the third argument at all.
I would like to propose this change as a patch but I am undecided if
the appropriate change is to pass an array as the third argument to
createLiteral or to test in createLiteral if the third argument is an
array or not and modify it appropriately for passing on to
String.format ...
Currently, I am using this:
OpenLayers.Style.createLiteral = function(value, context, args) {
if (typeof value == "string" && value.indexOf("${") != -1) {
value = OpenLayers.String.format(value, context, args);
value = (isNaN(value) || !value) ? value : parseFloat(value);
return value;
What I could do is:
OpenLayers.Style.createLiteral = function(value, context, feature) {
var args = typeof(feature) == 'array' ? feature : [feature];
return value;
Comments?
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://research.dmsolutions.ca/
More information about the Dev
