[OpenLayers-Dev] createLiteral enhancement proposal
Andreas Hocevar
ahocevar at opengeo.org
Sun Jun 21 12:29:08 EDT 2009
Hi Paul,
On Fri, Jun 19, 2009 at 5:14 PM, Paul Spencer<pspencer at dmsolutions.ca> wrote:
> In the context of calling functions to compute styles for features
> using the ${functionName} syntax, it would be very useful for me if
> the property being computed was passed to functionName() in addition
> to the feature itself. I've tested this locally by modifying
> createLiterals to pass an array with [feature,i] (where i is the
> property name) and createLiteral to replace feature with args, which
> is passed to String.format as the third value. This works perfectly
> for me. The only other use of createLiteral is in Rule, which does
> not use the third argument at all.
> I would like to propose this change as a patch but I am undecided if
> the appropriate change is to pass an array as the third argument to
> createLiteral or to test in createLiteral if the third argument is an
> array or not and modify it appropriately for passing on to
> String.format ...
> Currently, I am using this:
> OpenLayers.Style.createLiteral = function(value, context, args) {
> if (typeof value == "string" && value.indexOf("${") != -1) {
> value = OpenLayers.String.format(value, context, args);
> value = (isNaN(value) || !value) ? value : parseFloat(value);
> return value;
What about
OpenLayers.Style.createLiteral = function(value, context, feature, property) {
value = OpenLayers.String.format(value, context, [feature, property]);
return value;
Then you could have
createLiterals: function(style, feature) {
var context = this.context || feature.attributes || feature.data;
for (var i in this.propertyStyles) {
style[i] = OpenLayers.Style.createLiteral(style[i],
context, feature, i);
return style;
and would not have to worry about API changes.
Regards,
Andreas.
> Comments?
> __________________________________________
> Paul Spencer
> Chief Technology Officer
> DM Solutions Group Inc
> http://research.dmsolutions.ca/
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
