[OpenLayers-Dev] createLiteral enhancement proposal
Paul Spencer
pspencer at dmsolutions.ca
Sun Jun 21 12:54:15 EDT 2009
Thanks for commenting, Andreas ...
On 21-Jun-09, at 12:29 PM, Andreas Hocevar wrote:
> Hi Paul,
> On Fri, Jun 19, 2009 at 5:14 PM, Paul
> Spencer<pspencer at dmsolutions.ca> wrote:
>> In the context of calling functions to compute styles for features
>> using the ${functionName} syntax, it would be very useful for me if
>> the property being computed was passed to functionName() in addition
>> to the feature itself. I've tested this locally by modifying
>> createLiterals to pass an array with [feature,i] (where i is the
>> property name) and createLiteral to replace feature with args, which
>> is passed to String.format as the third value. This works perfectly
>> for me. The only other use of createLiteral is in Rule, which does
>> not use the third argument at all.
>> I would like to propose this change as a patch but I am undecided if
>> the appropriate change is to pass an array as the third argument to
>> createLiteral or to test in createLiteral if the third argument is an
>> array or not and modify it appropriately for passing on to
>> String.format ...
>> Currently, I am using this:
>> OpenLayers.Style.createLiteral = function(value, context, args) {
>> if (typeof value == "string" && value.indexOf("${") != -1) {
>> value = OpenLayers.String.format(value, context, args);
>> value = (isNaN(value) || !value) ? value : parseFloat(value);
>> return value;
> What about
> OpenLayers.Style.createLiteral = function(value, context, feature,
> property) {
> value = OpenLayers.String.format(value, context, [feature,
> property]);
> return value;
> Then you could have
> createLiterals: function(style, feature) {
> var context = this.context || feature.attributes ||
> feature.data;
> for (var i in this.propertyStyles) {
> style[i] = OpenLayers.Style.createLiteral(style[i],
> context, feature, i);
> return style;
> and would not have to worry about API changes.
I thought of this and then decided on passing an array in the (perhaps
unlikely) event that someone else thought of a need for other
arguments they would like passed through createLiteral to
String.format and beyond. If that won't happen, then passing a fourth
argument is probably the safer change (even though it is not an
APIMethod)feat.
I will propose your suggestion as the patch in trac with a comment
about my alternative and the possible reasons to implement one over
the other. I'll add it to http://trac.openlayers.org/ticket/2146
which proposes to modify createLiterals to combine the context,
attributes and data.
> Regards,
> Andreas.
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://research.dmsolutions.ca/
More information about the Dev
