[OpenLayers-Dev] SelectFeature control
Eric Lemoine
eric.c2c at gmail.com
Thu Mar 5 10:11:39 EST 2009
The highlightOnly control does not do feature unselection either, it
just highlights and unhighlights features (unhighlighting them only if
they're not selected).
Eric
2009/3/5, Alexandre Dube <adube at mapgears.com>:
> Hi Eric,
> That's a nice and great approach without hurting the core a all.
> There's just a small issue with this solution ( see below ).
> Keep up the excellent work,
> Alexandre
> Eric Lemoine wrote:
>> On Tue, Mar 3, 2009 at 7:05 PM, Eric Lemoine <eric.c2c at gmail.com> wrote:
>>> Alexandre
>>> I fully support the idea of being able to have two "highlight feature"
>>> controls working at the same time, one on hover and one on click.
>>> However i don't like the renderIntent array in the feature class, it
>>> brings extra complexity that I think is undesirable. I have to say
>>> though that i cannot think of a better solution at this point. Still
>>> thinking...
>>> Thanks for bringing this back up.
>> Alexandre,
>> What about this: add an highlightOnly boolean option to the select
>> feature control, if highlightOnly is true then do not select features,
>> just highlight them. Also, if highlightOnly is set to true, when
>> clicking or moving out of an highlighted feature do not unhighlight
>> the feature if it is in the selected features array, i.e. if it was
>> previously selected (by another select feature control).
> Control #1, select on click, color: blue
> Control #2, select on hover, color: yellow, highlightOnly
> Mouse over a feature, it's not selected but color changed to yellow. ( OK )
> Click on this feature, it's selected and color changed to blue. ( OK )
> Move moves over the feature, it remains blue ( OK )
> Move out of the feature, it remains blue ( OK )
> Move back over the feature, it's not selected but changes from blue to
> yellow ( OK )
> Move out, it remains yellow ( not OK : it should be drawn back to blue )
> Selecting a bunch of features on click with control #1 renders them to
> blue, but hovering them makes control #2 renders them to yellow instead.
> It's a small price to pay if we consider that your changes don't hurt
> the core at all, which is a good thing in my opinion.
> BUT ( sorry to bring that up again ^_^ ), a renderIntent "stack" would
> resolve this small issue. We would just need to call
> this.layer.drawFeature(feature) instead of not calling
> this.drawFeature(feature) to draw the feature back to its previous
> renderIntent.
> What do you ( and others ) think ?
>> See the attached patch. Note that patch isn't complete - the select
>> feature control should trigger "featurehighlighted" and
>> "featureunhighlighted" events to complete the picture.
>> What do you think?
>> Eric
> Alexandre Dubé
> Mapgears
> www.mapgears.com
Envoyé avec mon mobile
More information about the Dev
