[OpenLayers-Dev] SelectFeature control
Alexandre Dube
adube at mapgears.com
Thu Mar 5 11:09:50 EST 2009
Sorry, I should have written :
Control #1, select on click, color: blue
Control #2, highlight on hover, color: yellow, highlightOnly
The problem is that control #2 :
highlight a feature even if it's selected
doesn't unhighlight a feature that is selected
so, a blue-selected-feature becomes yellow, and then moving out it
remains yellow. Do you see what I mean ?
Alexandre
Eric Lemoine wrote:
> The highlightOnly control does not do feature unselection either, it
> just highlights and unhighlights features (unhighlighting them only if
> they're not selected).
> Eric
> 2009/3/5, Alexandre Dube <adube at mapgears.com>:
>> Hi Eric,
>> That's a nice and great approach without hurting the core a all.
>> There's just a small issue with this solution ( see below ).
>> Keep up the excellent work,
>> Alexandre
>> Eric Lemoine wrote:
>>> On Tue, Mar 3, 2009 at 7:05 PM, Eric Lemoine <eric.c2c at gmail.com> wrote:
>>>> Alexandre
>>>> I fully support the idea of being able to have two "highlight feature"
>>>> controls working at the same time, one on hover and one on click.
>>>> However i don't like the renderIntent array in the feature class, it
>>>> brings extra complexity that I think is undesirable. I have to say
>>>> though that i cannot think of a better solution at this point. Still
>>>> thinking...
>>>> Thanks for bringing this back up.
>>> Alexandre,
>>> What about this: add an highlightOnly boolean option to the select
>>> feature control, if highlightOnly is true then do not select features,
>>> just highlight them. Also, if highlightOnly is set to true, when
>>> clicking or moving out of an highlighted feature do not unhighlight
>>> the feature if it is in the selected features array, i.e. if it was
>>> previously selected (by another select feature control).
>> Control #2, select on hover, color: yellow, highlightOnly
>> Mouse over a feature, it's not selected but color changed to yellow. ( OK )
>> Click on this feature, it's selected and color changed to blue. ( OK )
>> Move moves over the feature, it remains blue ( OK )
>> Move out of the feature, it remains blue ( OK )
>> Move back over the feature, it's not selected but changes from blue to
>> yellow ( OK )
>> Move out, it remains yellow ( not OK : it should be drawn back to blue )
>> Selecting a bunch of features on click with control #1 renders them to
>> blue, but hovering them makes control #2 renders them to yellow instead.
>> It's a small price to pay if we consider that your changes don't hurt
>> the core at all, which is a good thing in my opinion.
>> BUT ( sorry to bring that up again ^_^ ), a renderIntent "stack" would
>> resolve this small issue. We would just need to call
>> this.layer.drawFeature(feature) instead of not calling
>> this.drawFeature(feature) to draw the feature back to its previous
>> renderIntent.
>> What do you ( and others ) think ?
>>> See the attached patch. Note that patch isn't complete - the select
>>> feature control should trigger "featurehighlighted" and
>>> "featureunhighlighted" events to complete the picture.
>>> What do you think?
>>> Eric
>> Alexandre Dubé
>> Mapgears
>> www.mapgears.com
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev
