[OpenLayers-Dev] ESRI and OpenLayers
Christopher Schmidt
crschmidt at metacarta.com
Fri Mar 6 08:18:12 EST 2009
On Tue, Mar 03, 2009 at 11:51:08AM -0800, Matt Priour wrote:
> I was going to prepare unit tests for the ArcGISCache layer today. Since it
> inherits directly from TMS and only overwrites:
> intialize
> clone
> getTileUrl
> are these the ONLY functions which require testing. Or should I also test
> all the same test that are in the tests/Layers/TMS.html
This seems reasonable to me -- testing only the changed functions.
Also, one thing I'd really like to see is an example, including, if
possible, how it was set up -- last I remembere there was soe problem
with describing how the grid got set up or something like that.
Thanks,
Christopher Schmidt
MetaCarta
More information about the Dev
