[OpenLayers-Dev] ESRI and OpenLayers
carls
carlshe at 163.com
Sun Mar 8 10:03:07 EDT 2009
I had tested 'root/sandbox/dzwarg/openlayers/lib/OpenLayers/Layer/ArcIMS.js'
and 'root/sandbox/dzwarg/openlayers/lib/OpenLayers/Format/ArcXML.js' with
OL2.7. It works well.
I hope and would like to see the support of ArcIMS in OL2.8, if possible.
Thanks.
Christopher Schmidt-2 wrote:
> Eric,
> Your email led me into a response that is really far more appropriate to
> the entire dev list in my opinion. ESRI and OpenLayers is a particularly
> large hole in the library support, and I wanted to really get down a lot
> of my thoughts on why this is. Please take all this with a large grain
> of salt as being my personal point of view... but perhaps not an
> entirely-inaccurate one, given my level of involvement in the project.
> On Mon, Mar 02, 2009 at 04:27:21PM -0700, Eric Wolf wrote:
>> Christopher,
>> I hate to open old wounds, but I'm preparing a presentation centered
>> around generating a tile cache consumable by OpenLayers but based on
>> an ArcGIS map layout. I've tried some different configurations:
> So, I want to start off by saying this: No existing OpenLayers core
> contributor has, in any major way, a personal or professional motivation
> towards supporting ESRI's web services, so far as I am aware. This
> includes the OpenGeo community (generally speaking, tightly coupled with
> GeoServer), the Camptocamp group (which works almost exclusively outside
> the realm of ESRI, as far as I've observed: possibly motivated by
> Europe's lack of proprietary buy-in, hooray), or the DM Solutions
> (primarily around MapGuide, and MapServer) or MapGears (primarily around
> MapServer) contributors. I expect that if you came with $$ to any of
> these groups, they would be likely to be able to help you, but it's not
> so common of a problem to make it worthwhile for them to spend time
> maintaining ESRI-specific code without a customer asking for it.
> With that in mind, almost all work on ESRI-related developments thus far
> has been by non-core contributors to the project, and OpenLayers has,
> in some cases, not had a great track record with non-core contributors
> of content doing the work to get their code in trunk.
> The ESRI AGS code developed thus far has been prey to this: several
> people have used it, but not:
> * Documented it
> * Tested it
> * Created examples for it
> As such, the code is not something that the OpenLayers community can
> support without a strong leader stepping up and taking on the task on
> the code.
> Some counter-examples to this are:
> * The recently committed ArcGIS 9.3 REST API layer.
> * The in-review ESRI ArcXML layer.
> Both of these sets of code have had committed developers who have
> written tests, provided documented examples, etc. in clean, well-laid
> out patches.
> Based on your problem description on the mailing list -- something you
> neglected to include in this email, which makes it difficult to respond
> to precisely -- I can not describe what the best solution is for you,
> based on my personal knowledge. I don't use any ESRI products or
> anything else.
> Though I don't know if it's the best thing for your use case, I do feel
> that it would be beneficial to the OpenLayers community to have access
> to ESRI's map caches. Cached map tiles are clearly much faster than
> non-cached map tiles, and the recent developments of ESRI's -- making
> available, for example, sampleserver.esri.com or whatever it is -- make
> this type of development much simpler.
> However, to accomplish this goal, there still needs to be a champion of
> the task -- someone who is reasonably experienced in Javascript, and
> willing to step up and take on the task of providing the OpenLayers
> community with the support it needs to get this support into the
> library. This means that, for example, documentation and examples would
> need to be written, etc. and the contributo would likely need to
> demonstrate some willingness to continue to support developers in
> maintaining the code, since none of us are, as far as i know,
> particularly well-versed or highly motivated to maintain the code at a
> reasonable level of quality on our own.
> You proposed a number of possible solutions:
>> * Turning on WMS in ArcServer and pointing TileCache at it. Works but
>> ArcServer wants to serve the layers independently, so I get back to
>> the SLD problem.
> To me, this seems like a configuation issue. That is, the WMS serves
> layers individually, but they're typically possible to combined, with
> something like:
> layers=0,1,2
> In your TileCache config. However, I only know very little of ESRI's
> software, so I can't comment on that for sure, and I haven't seen any
> links that help me look at your setup to confirm-or-dis-confirm this
> notion of mine.
>> * Generating a tile cache out of ArcServer and kludging TileCache to
>> serve it up.
> I don't know what 'ArcServer' is, but I expect that this would have
> essentially the same problem that has existed i ArcGIS caches in the
> past, which is that most people who have access to caches don't know
> what the parameters used to create the cache are.
>> And lastly:
>> * Pulling the AGS plugin for OpenLayers out of the sandbox
> This code should probably be in trunk, as described above. The fact that
> it is not is because no sufficiently motivated Javascript developer has
> made it so. (As Mr. Schaub pointed out at one point, these things arent
> meant to happen magically; in Open Source, you need to either pay
> someone to do it, or do it yourself.)
>> I haven't actually tried the last bit because of some of your emails
>> I've found from 2007. It sounds like AGS is a dead-end. Is this true?
>> Is there a specific reason?
> AGS is not a dead-end, but you probably read emails where I was
> expressing my frustration, centered mostly around the stuff above.
> Specifically, the same problem as there is in many aspects of the
> project has arisen here:
> * Someone writes some code
> * The code is insufficient, poorly documented, or simply 'not done'
> * The author of the code expects it to get in trunk
> * Requests to do more work to make it happen are ignored.
> The general assumption in these cases seems to be that if someone writes
> some code, it will automatically be in trunk, which is simply
> unrealistic. OpenLayers is a high quality code library, and it seems
> completely reasonable to me that in order to keep it that way, we have
> to maintain some standards. However, this means that some code does not
> make it into trunk in a timely manner, and the patch authors feel
> shunned or ignored. Although this is almost always not the case, the
> emotions there are very frustrating as a developer: the expectation that
> patches lead to changes in the library 'for free' is just unfair to the
> core development team.
> In this case, I was unable to st up the ArcGIS cached layer code to talk
> to any server I could find documented on the web. If I an't do it, I
> can't imagine that most users can do it: I'm a pretty smart guy in
> general. If I cant' pull it off, then it is probably the case that
> others can't either, and that means that putting it in trunk is asking
> for pain. With that in mind, I saw no significant personal benefit to
> working on it, and the code has sat.
> My expressed frustration is/was probably unfair. I'm not aware of any
> problem with the code as it exists -- except that people are using it,
> and not giving back to the community by trying to get it into trunk. I
> find that combination extremely unfair, given the amount of work that so
> many people put in to make the library possible. I'd love to see some
> organizations out there who are using this code really invest in it, and
> make the library better for everyone as a result. This could come in the
> form of paying developers to work on it, project sponsorship with a
> stated request -- though not binding, clearly somewhat motivating -- or
> other potential venues. Without any of this kind of support,
> organizations -- of which there are several -- using the AGS code are
> simply taking from the library, and not giving back. that type of
> behavior is frustrating to me, and that has probably come through in
> previous emails.
>> And input would be greatly appreciated.
> Using ESRI services in OpenLayers needs champions -- people who are
> willing to truly support the cause. ArcXML has a champion in the form of
> dzwarg, who has been working with me on an ArcXML ticket. ArcGIS rest
> layer had a champion in the form of Jeff Adams. AGS cache needs the
> same. The community could probably rally up and make this support
> happen: lots of people have expressed interest. Open Source isnt all
> about things being done for you, and I'd love to see some of the users
> of the software really invest in OpenLayers more than they have up to
> this point. ESRI-specific services are a great example of this, where
> there's a lot of code floating about, but relatively limited support of
> it outside of the companies using it or specific use cases, and that's
> a great example of what I'd love to see change.
> Sorry for using you email as a jumping off point for a 'rant' like this,
> but the state of ESRI-in-OpenLayers is an excellent example of what
> *feels* like poor community support of library in favor of immediate
> needs, and I really like the idea of that changing. (And if I'm
> completely ignoring a significant effort in this regard, this is a
> perfect oppourtunity for the existing community members whose work I
> have been ignoring to step up and tell me how wrong I am!)
> Regards,
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Regards, Carl SHE
View this message in context: http://n2.nabble.com/ESRI-and-OpenLayers-tp2412861p2444558.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
