[OpenLayers-Dev] Deactivate BaseLayer (tilecache),
but requests are still executed
T. Vieira
tvieira at xlm.pt
Sun Mar 15 18:21:28 EDT 2009
In my case the baselayer could be switch on/off.
I switch the baselayer to have a better performance with many layers over
the map.
So, my question remains.
Is that a reasonable change in the Openlayers code?
Thanks,
T Vieira
bwoodall wrote:
> Howdy Tiago
> On Fri, 2009-03-13 at 05:36 -0700, T. Vieira wrote:
>> Hi,
>> Using OL2.7 - IE6.
>> I'm using tilecache for baselayer, and when i deactivate the checkBox
>> from
>> that layer, visibility turns off.
>> But, when i do a PAN or ZOOM the request to tilecache server is still
>> executed.
>> I don't know if my code have a bug in some place, or if is a bug from
>> Openlayers.
> I don't think of this as a bug in either, since the baselayer is the
> foundation of your map from which you can add other items (overlays,
> freatures, ...) to highlight additional information or focus the viewer
> to a particular area on the baselayer and I think the baselayer was
> never meant to be turned off.
>> I made a change to get it work correctly:
> Isn't OpenSource Cool!
>> **** OpenLayers/Tile/image.js ****
>> draw: function() {
>> + var drawTile = false;
>> if (this.layer != this.layer.map.baseLayer &&
>> this.layer.reproject)
>> this.bounds = this.getBoundsFromBaseLayer(this.position);
>> + if (this.layer.visibility != 0)
>> - var drawTile = OpenLayers.Tile.prototype.draw.apply(this,
>> arguments);
>> + drawTile = OpenLayers.Tile.prototype.draw.apply(this,
>> arguments);
>> When the layer visibility is 0, the drawTile variable mantains false, so
>> the
>> request isn't executed.
>> Can you test it some way?
>> Thanks,
>> Tiago Vieira
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
View this message in context: http://n2.nabble.com/Deactivate-BaseLayer-%28tilecache%29%2C-but-requests-are-still-executed-tp2473163p2483205.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
