[OpenLayers-Dev] Bug in ie7 (maybe ie6 also) in /OpenlLayers/lib/OpenLayers/Proptocol/HTTP.js on line 324:
aducos at hbs-research.com aducos at hbs-research.com
Mon Mar 16 06:20:46 EDT 2009
When I run openlayers in ie7 I have an error in
'status' is Null or is not an object
This does not happen in firefox.
Now if I look closer to the code, it is a bug in a method
'handleResponse' of the object OpenLayers.Protocol.HTTP
 the method begins like this:
handleResponse: function(resp, options) {
        var request = resp.priv;
        if(options.callback) {
            if(request.status >= 200 && request.status < 300) { ...
Now in my case I don't exactly know why resp.priv is null. So I just
changed the code like this and all seams to work fine (in ie and firefox):
            if(request && request.status >= 200 && request.status < 300)
This would just check if request is not null before trying to see if
there is a status with it. Anyway if "request" is null the status can
not be >= 200 and < 300. So the corrected code is not wrong.
More information about the Dev mailing list
