[OpenLayers-Dev] Bug in ie7 (maybe ie6 also) in
	/OpenlLayers/lib/OpenLayers/Proptocol/HTTP.js on line 324:
    Ivan Grcic
    igrcic at gmail.com
    Mon Mar 16 08:00:22 EDT 2009
i think you hit http://trac.openlayers.org/ticket/1896
Its fixed in trunk,
cheers
Ivan
On Mon, Mar 16, 2009 at 11:20 AM, aducos at hbs-research.com <
aducos at hbs-research.com> wrote:
> When I run openlayers in ie7 I have an error in
> 'status' is Null or is not an object
> This does not happen in firefox.
> Now if I look closer to the code, it is a bug in a method
> 'handleResponse' of the object OpenLayers.Protocol.HTTP
>  the method begins like this:
> handleResponse: function(resp, options) {
>        var request = resp.priv;
>        if(options.callback) {
>            if(request.status >= 200 && request.status < 300) { ...
> Now in my case I don't exactly know why resp.priv is null. So I just
> changed the code like this and all seams to work fine (in ie and firefox):
>            if(request && request.status >= 200 && request.status < 300)
> This would just check if request is not null before trying to see if
> there is a status with it. Anyway if "request" is null the status can
> not be >= 200 and < 300. So the corrected code is not wrong.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20090316/684b768b/attachment.html
More information about the Dev
