[OpenLayers-Dev] ESRI and OpenLayers
Christopher Schmidt
crschmidt at metacarta.com
Tue Mar 24 07:41:23 EDT 2009
On Fri, Mar 06, 2009 at 08:12:33AM -0600, Matt Priour wrote:
> Yes, I'm doing an example.
> The problem last time was that the tile URL was calculated based on the
> upper left corner of the bounds. If the OL Map grid and the tile grid were
> off by even 0.00001 units, certain tiles would get repeated, others
> skipped. The behavior was very unpredictable but worse at closer zoom
> levels and projected grids with large coordinate values.
> My version uses the bound center which avoids those issues.
Matt,
We're coming up on a deadline for inclusion into 2.8. I don't mind if
you don't write tests, but please do write an example and get it into
the patch?
Thanks,
Christopher Schmidt
MetaCarta
More information about the Dev
