[OpenLayers-Dev] ESRI and OpenLayers
Matt Priour
mpriour at kestrelcomputer.com
Tue Mar 24 09:29:47 EDT 2009
Yes, it has been weighting on me that I needed to do that. I will do that
sometime today.
Thanks for the gentle reminder.
Matt Priour
From: "Christopher Schmidt" <crschmidt at metacarta.com>
Sent: Tuesday, March 24, 2009 6:41 AM
To: "Matt Priour" <mpriour at kestrelcomputer.com>
Cc: <dev at openlayers.org>
Subject: Re: [OpenLayers-Dev] ESRI and OpenLayers
> On Fri, Mar 06, 2009 at 08:12:33AM -0600, Matt Priour wrote:
>> Yes, I'm doing an example.
>> The problem last time was that the tile URL was calculated based on the
>> upper left corner of the bounds. If the OL Map grid and the tile grid
>> were
>> off by even 0.00001 units, certain tiles would get repeated, others
>> skipped. The behavior was very unpredictable but worse at closer zoom
>> levels and projected grids with large coordinate values.
>> My version uses the bound center which avoids those issues.
> Matt,
> We're coming up on a deadline for inclusion into 2.8. I don't mind if
> you don't write tests, but please do write an example and get it into
> the patch?
> Thanks,
> Christopher Schmidt
> MetaCarta
More information about the Dev
