[OpenLayers-Dev] maps with all "overlays"
Tim Schaub
tschaub at opengeo.org
Tue Mar 31 13:06:49 EDT 2009
Hey-
Update: I've modified the patch for #2004 so that if you set
map.allOverlays to true, all layers will be consistently treated as
overlays (their isBaseLayer property will be set to false).
Thanks for any review.
Tim
Tim Schaub wrote:
> Hey-
> I've put together a pretty simple patch [1] that allows a map to be
> configured so that the lowest layer in the draw order is always treated
> as the base layer.
> With this patch, if you configure your map with allOverlays: true and
> configure every layer with isBaseLayer: false, you can have a map with
> any number (including zero) of layers visible or invisible.
> The patch is marked for commit, and I'm happy to commit it. If anybody
> has any comments about *not* wanting this, please speak up.
> Tim
> [1] see http://trac.openlayers.org/ticket/2004
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
