[OpenLayers-Dev] projection through urn syntax
bartvde at osgis.nl
bartvde at osgis.nl
Mon May 4 07:25:30 EDT 2009
Hi list,
Currently Proj4js and OpenLayers use EPSG:XXXX as the syntax for
projections, whereas OWSContext uses the urn syntax, for example:
urn:ogc:def:crs:EPSG:6.6:4326
So in my OWSContext Format I use a small utility function which transforms
this into EPSG:4326.
The urn syntax can also be present in GML3 files.
Question:
-would this belong in OpenLayers' Projection.js or in Proj4js?
Best regards,
Bart
More information about the Dev
