[OpenLayers-Dev] projection through urn syntax
bartvde at osgis.nl
bartvde at osgis.nl
Mon May 4 07:37:10 EDT 2009
Hi Didier,
great! I had not seen that.
So I can just pass a urn string to the OpenLayers.Projection object
constructor.
Best regards,
Bart
> Le Lundi 4 Mai 2009 13:25, bartvde at osgis.nl a écrit :
>> Hi list,
>> Currently Proj4js and OpenLayers use EPSG:XXXX as the syntax for
>> projections, whereas OWSContext uses the urn syntax, for example:
>> urn:ogc:def:crs:EPSG:6.6:4326
>> So in my OWSContext Format I use a small utility function which
>> transforms
>> this into EPSG:4326.
>> The urn syntax can also be present in GML3 files.
>> Question:
>> -would this belong in OpenLayers' Projection.js or in Proj4js?
> I have added URN in Proj4js. At least, it is in the trunk (See
> http://trac.osgeo.org/proj4js/ticket/17)
> didier
>> Best regards,
>> Bart
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> Didier RICHARD, chef du pôle technique Géoportail pour l'IGN
> Institut Geographique National tel: +33/0 1.43.98.83.23
> 2/4 Avenue Pasteur fax: +33/0 1.43.98.80.88
> F-94165 St-Mande Cedex e-mail: Didier.Richard at ign.fr
More information about the Dev
