[OpenLayers-Dev] .JPG image in OverviewMap
XinGang Li slinavlee at gmail.com
Thu May 7 04:49:58 EDT 2009
layers is a APIProperty.
ol_miniMap = new OpenLayers.Control.OverviewMap( {
            mapOptions: {
                  maxExtent: new OpenLayers.Bounds(extent->minx,
extent->miny, extent->maxx, extent->maxy),
                  maxResolution: ResolutionMap,
                  projection: ProjectionMap,
                  units: UnitsMap,
                  numZoomLevels: '1'
            size: new OpenLayers.Size('150','150'),
            layers: [minimapImgLayer] } )
On Thu, May 7, 2009 at 3:43 PM, Jean-Daniel JDG. GONON <jdg at geosphere.fr>wrote:
>  Yes I want to use this idea, so I modify my code like this :
> var minimapImgLayer = new OpenLayers.Layer.Image('ImageLayer',
> 'reference.jpg',
>       new OpenLayers.Bounds(extent->minx, extent->miny, extent->maxx,
> extent->maxy),
>       new OpenLayers.Size('150', '150'), {numZoomLevels: '1',
> alwaysInRange: true} );
> var ol_miniMap;
> var ol_Map = new OpenLayers.Map('viewport', {
>       controls: [ ol_miniMap = new OpenLayers.Control.OverviewMap( {
>             mapOptions: {
>                   units: UnitsMap,
>                   layers: [minimapImgLayer],
>                   numZoomLevels: '1'
>             }, size: new OpenLayers.Size('150','150') } ) ],
>       maxExtent: new OpenLayers.Bounds(extent->minx, extent->miny,
>       scales: [NewScalesMap],
>       units: UnitsMap,
>       i: szImgFormat,
>       tileSize: new OpenLayers.Size('tileWidth','tileHeight'),
> }, numZoomLevels = NumberScalesMap );
> The reference.jpg image has a resolution of 150*150 pixels.
> With this code, I have no error message.
> But the overview map display a clone of main map, instead of my JPG image.
> I don’t know why ..??
> Is what someone have an idea of solution ??
> Thank you in advance !!
> JDG
> *De :* XinGang Li [mailto:slinavlee at gmail.com]
> *Envoyé :* mercredi 6 mai 2009 07:25
> *À :* Jean-Daniel JDG. GONON
> *Cc :* dev at openlayers
> *Objet :* Re: [OpenLayers-Dev] .JPG image in OverviewMap
> You can use the OpenLayers.Layer.Image with one zoom level in your overview
> map, like this:
>          var imageLayer = new OpenLayers.Layer.Image(
>                 "ImageLayer",
>                 "test.jpg",
>                 new OpenLayers.Size(150, 150),
>                 {numZoomLevels: 1, alwaysInRange: true}
> On Tue, May 5, 2009 at 6:12 PM, Jean-Daniel JDG. GONON <jdg at geosphere.fr>
> wrote:
> For my question :
> I can’t specify LAYER attribut of overviewMap control, because this JPG
> image is generated by an admin according wanted layers mapfile’s (it’s
> generated when it’s necessary) : the wanted layers can change often, so I
> can’t modify LAYER attribute each times.
> Selected layers by the admin in the JPG image aren’t saved elsewhere.
> Zooming function doesn’t interrest me : the JPG image has 150*150px
> resolution, and I want always display the full map in OverviewMap (whatever
> the scale and the current position in OpenLayers map).
> But I want to keep a moving function between OpenLayers map and
> OverviewMap...
> Thank you in advance.
> JDG
> *De :* Jean-Daniel JDG. GONON
> *Envoyé :* lundi 4 mai 2009 14:14
> *À :* 'dev at openlayers.org'
> *Objet :* .JPG image in OverviewMap
> Hi all,
> Is it possible to load a .JPG image in the overview map control ?
> In my application, a JPG mini-map is generated by an admin according to
> layers selected or not.
> I want to load this JPG image (with a point to locate the current
> position), with a fixed size and without zoom function.
> Thank you for answers
> JDG
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
> Li XinGang
> EMail: slinavlee at gmail.com
> Blog:   avlee.cnblogs.com
> Site:    www.mapboost.org
Li XinGang
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20090507/f5740701/attachment.html
More information about the Dev mailing list
