[OpenLayers-Dev] .JPG image in OverviewMap
Jean-Daniel JDG. GONON jdg at geosphere.fr
Thu May 7 03:43:44 EDT 2009
Yes I want to use this idea, so I modify my code like this :
var minimapImgLayer = new OpenLayers.Layer.Image('ImageLayer', 'reference.jpg',
      new OpenLayers.Bounds(extent->minx, extent->miny, extent->maxx, extent->maxy),
      new OpenLayers.Size('150', '150'), {numZoomLevels: '1', alwaysInRange: true} );
var ol_miniMap;
var ol_Map = new OpenLayers.Map('viewport', {
      controls: [ ol_miniMap = new OpenLayers.Control.OverviewMap( {
            mapOptions: {
                  maxExtent: new OpenLayers.Bounds(extent->minx, extent->miny, extent->maxx, extent->maxy),
                  maxResolution: ResolutionMap,
                  projection: ProjectionMap,
                  units: UnitsMap,
                  layers: [minimapImgLayer],
                  numZoomLevels: '1'
            }, size: new OpenLayers.Size('150','150') } ) ],
      scales: [NewScalesMap],
      units: UnitsMap,
      i: szImgFormat,
      tileSize: new OpenLayers.Size('tileWidth','tileHeight'),
}, numZoomLevels = NumberScalesMap );
The reference.jpg image has a resolution of 150*150 pixels.
With this code, I have no error message.
But the overview map display a clone of main map, instead of my JPG image.
I don't know why ..??
Is what someone have an idea of solution ??
Thank you in advance !!
JDG
De : XinGang Li [mailto:slinavlee at gmail.com]
Envoyé : mercredi 6 mai 2009 07:25
À : Jean-Daniel JDG. GONON
Cc : dev at openlayers
Objet : Re: [OpenLayers-Dev] .JPG image in OverviewMap
You can use the OpenLayers.Layer.Image with one zoom level in your overview map, like this:
         var imageLayer = new OpenLayers.Layer.Image(
                "ImageLayer",
                "test.jpg",
                new OpenLayers.Size(150, 150),
                {numZoomLevels: 1, alwaysInRange: true}
On Tue, May 5, 2009 at 6:12 PM, Jean-Daniel JDG. GONON <jdg at geosphere.fr> wrote:
For my question :
I can't specify LAYER attribut of overviewMap control, because this JPG image is generated by an admin according wanted layers mapfile's (it's generated when it's necessary) : the wanted layers can change often, so I can't modify LAYER attribute each times.
Selected layers by the admin in the JPG image aren't saved elsewhere.
Zooming function doesn't interrest me : the JPG image has 150*150px resolution, and I want always display the full map in OverviewMap (whatever the scale and the current position in OpenLayers map).
But I want to keep a moving function between OpenLayers map and OverviewMap...
Thank you in advance.
JDG
De : Jean-Daniel JDG. GONON
Envoyé : lundi 4 mai 2009 14:14
À : 'dev at openlayers.org'
Objet : .JPG image in OverviewMap
Hi all,
Is it possible to load a .JPG image in the overview map control ?
In my application, a JPG mini-map is generated by an admin according to layers selected or not.
I want to load this JPG image (with a point to locate the current position), with a fixed size and without zoom function.
Thank you for answers
JDG
Dev mailing list
Dev at openlayers.org
http://openlayers.org/mailman/listinfo/dev
Li XinGang
EMail: slinavlee at gmail.com
Blog:   avlee.cnblogs.com
Site:    www.mapboost.org
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20090507/22c0289b/attachment.html
More information about the Dev mailing list
