[OpenLayers-Dev] .JPG image in OverviewMap
XinGang Li
slinavlee at gmail.com
Wed May 6 01:24:41 EDT 2009
You can use the OpenLayers.Layer.Image with one zoom level in your overview
map, like this:
var imageLayer = new OpenLayers.Layer.Image(
"ImageLayer",
"test.jpg",
new OpenLayers.Size(150, 150),
{numZoomLevels: 1, alwaysInRange: true}
On Tue, May 5, 2009 at 6:12 PM, Jean-Daniel JDG. GONON <jdg at geosphere.fr>wrote:
> For my question :
> I can’t specify LAYER attribut of overviewMap control, because this JPG
> image is generated by an admin according wanted layers mapfile’s (it’s
> generated when it’s necessary) : the wanted layers can change often, so I
> can’t modify LAYER attribute each times.
> Selected layers by the admin in the JPG image aren’t saved elsewhere.
> Zooming function doesn’t interrest me : the JPG image has 150*150px
> resolution, and I want always display the full map in OverviewMap (whatever
> the scale and the current position in OpenLayers map).
> But I want to keep a moving function between OpenLayers map and
> OverviewMap...
> Thank you in advance.
> JDG
> *De :* Jean-Daniel JDG. GONON
> *Envoyé :* lundi 4 mai 2009 14:14
> *À :* 'dev at openlayers.org'
> *Objet :* .JPG image in OverviewMap
> Hi all,
> Is it possible to load a .JPG image in the overview map control ?
> In my application, a JPG mini-map is generated by an admin according to
> layers selected or not.
> I want to load this JPG image (with a point to locate the current
> position), with a fixed size and without zoom function.
> Thank you for answers
> JDG
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Li XinGang
EMail: slinavlee at gmail.com
Blog: avlee.cnblogs.com
Site: www.mapboost.org
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20090506/26b2f61b/attachment.html
More information about the Dev
