[OpenLayers-Dev] .JPG image in OverviewMap
Jean-Daniel JDG. GONON
jdg at geosphere.fr
Thu May 14 12:03:41 EDT 2009
Hi
As I said in my last mail, I want to display a .JPG image in an OverviewMap control.
I view these sites (http://workshops.opengeo.org/openlay.../controls.html , http://trac.openlayers.org/wiki/Control/OverviewMap ) to help me.
To to this display, I have this code :
Creation of the image layer to display in the overviewMap control :
minimapImgLayer = new OpenLayers.Layer.Image('ImageLayer',
'C:/ms4w/minicarte/reference.jpg',
new OpenLayers.Bounds(937134.75,281924.76,942621,287411.01),
new OpenLayers.Size('150', '150'),
{numZoomLevels: '1', alwaysInRange: true});
Creation of the main map with OverviewMap control :
ol_Map = new OpenLayers.Map('viewport', {
controls: [ol_miniMap = new OpenLayers.Control.OverviewMap( {
layers:[minimapImgLayer],
size: new OpenLayers.Size('150','150')
maxExtent: new OpenLayers.Bounds(937134.75,281924.76,942621,287411.01),
scales: [25000,10000,5000,2500,1000],
maxResolution: '96',
units: 'm',
i: 'JPEG',
tileSize: new OpenLayers.Size('400','400'),
projection: 'init=epsg:27562'
}, numZoomLevels = '5');
Creation of KaMap layer for the main map :
KaMapLayer = new OpenLayers.Layer.KaMap( 'Couche_KaMap',
'http://localhost/kernel/myKaTile.php',
{ map: 'Couche_KaMap',
qId:'-1',
i: 'JPEG',
la:'Couche0,Couche1,Couche2,Couche3,Couche4'
ol_Map.addLayer(KaMapLayer);
ol_Map.zoomToMaxExtent();
The main map is displayed correctely.
But nothing is displayed in OverviewMap control.
Is somebody has an idea to help me ? ?
Thank you !!
JDG
De : Jean-Daniel JDG. GONON
Envoyé : jeudi 7 mai 2009 09:44
À : 'XinGang Li'
Cc : dev at openlayers
Objet : RE: [OpenLayers-Dev] .JPG image in OverviewMap
Yes I want to use this idea, so I modify my code like this :
var minimapImgLayer = new OpenLayers.Layer.Image('ImageLayer', 'reference.jpg',
new OpenLayers.Bounds(extent->minx, extent->miny, extent->maxx, extent->maxy),
new OpenLayers.Size('150', '150'), {numZoomLevels: '1', alwaysInRange: true} );
var ol_miniMap;
var ol_Map = new OpenLayers.Map('viewport', {
controls: [ ol_miniMap = new OpenLayers.Control.OverviewMap( {
mapOptions: {
maxExtent: new OpenLayers.Bounds(extent->minx, extent->miny, extent->maxx, extent->maxy),
maxResolution: ResolutionMap,
projection: ProjectionMap,
units: UnitsMap,
layers: [minimapImgLayer],
numZoomLevels: '1'
}, size: new OpenLayers.Size('150','150') } ) ],
scales: [NewScalesMap],
units: UnitsMap,
i: szImgFormat,
tileSize: new OpenLayers.Size('tileWidth','tileHeight'),
}, numZoomLevels = NumberScalesMap );
The reference.jpg image has a resolution of 150*150 pixels.
With this code, I have no error message.
But the overview map display a clone of main map, instead of my JPG image.
I don't know why ..??
Is what someone have an idea of solution ??
Thank you in advance !!
JDG
De : XinGang Li [mailto:slinavlee at gmail.com]
Envoyé : mercredi 6 mai 2009 07:25
À : Jean-Daniel JDG. GONON
Objet : Re: [OpenLayers-Dev] .JPG image in OverviewMap
You can use the OpenLayers.Layer.Image with one zoom level in your overview map, like this:
var imageLayer = new OpenLayers.Layer.Image(
"ImageLayer",
"test.jpg",
new OpenLayers.Size(150, 150),
{numZoomLevels: 1, alwaysInRange: true}
On Tue, May 5, 2009 at 6:12 PM, Jean-Daniel JDG. GONON <jdg at geosphere.fr> wrote:
For my question :
I can't specify LAYER attribut of overviewMap control, because this JPG image is generated by an admin according wanted layers mapfile's (it's generated when it's necessary) : the wanted layers can change often, so I can't modify LAYER attribute each times.
Selected layers by the admin in the JPG image aren't saved elsewhere.
Zooming function doesn't interrest me : the JPG image has 150*150px resolution, and I want always display the full map in OverviewMap (whatever the scale and the current position in OpenLayers map).
But I want to keep a moving function between OpenLayers map and OverviewMap...
Thank you in advance.
JDG
Envoyé : lundi 4 mai 2009 14:14
À : 'dev at openlayers.org'
Objet : .JPG image in OverviewMap
Hi all,
Is it possible to load a .JPG image in the overview map control ?
In my application, a JPG mini-map is generated by an admin according to layers selected or not.
I want to load this JPG image (with a point to locate the current position), with a fixed size and without zoom function.
Thank you for answers
JDG
Dev mailing list
Dev at openlayers.org
http://openlayers.org/mailman/listinfo/dev
Li XinGang
EMail: slinavlee at gmail.com
Blog: avlee.cnblogs.com
Site: www.mapboost.org
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20090514/1ff58bf4/attachment.html
More information about the Dev
