[OpenLayers-Dev] Popups on different GML Layers with
SelectFeature
Christopher Schmidt
crschmidt at metacarta.com
Fri May 15 09:35:29 EDT 2009
On Fri, May 15, 2009 at 06:13:28AM -0700, Simo D wrote:
> Hi, I'm trying to use the new trunk SelectFeature and RootContainer to add
> custom popups on three different GML layers.
> Now I'm passing the layers as an array to the SelectFeature constructor. But
> nothing changes from the 2.7 api, in most browsers (except for safari 4),
> the popups don't show.
> This is the code:
> var popups = new
> OpenLayers.Control.SelectFeature([gdacs_earth,gdacs_cyclones,gdacs_floods],
> GeorssPopups.init());
> map.addControl(popups);
> popups.activate();
> GeorssPopups implements the onSelect and onUnselect events.
> Is still there something wrong in my code?
It's hard to tell, since there's no information here about the *rest* of
your code. Can you give a link?
-- Chris
> Thanks in advance.
> Simone
> View this message in context: http://n2.nabble.com/Popups-on-different-GML-Layers-with-SelectFeature-tp2907685p2907685.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Christopher Schmidt
MetaCarta
More information about the Dev
