[OpenLayers-Dev] Popups on different GML Layers with
SelectFeature
Simo D
simone.dalmasso at gmail.com
Mon May 18 03:45:51 EDT 2009
Hi, this is the link: http://130.192.92.159/mapfish/prove/sdi_layout.html
Ithaca sdi .
It's a blocking issue for me, so I really appreciate any advice.
Thanks a lot.
Simone.
Christopher Schmidt-2 wrote:
> On Fri, May 15, 2009 at 06:13:28AM -0700, Simo D wrote:
>> Hi, I'm trying to use the new trunk SelectFeature and RootContainer to
>> add
>> custom popups on three different GML layers.
>> Now I'm passing the layers as an array to the SelectFeature constructor.
>> But
>> nothing changes from the 2.7 api, in most browsers (except for safari 4),
>> the popups don't show.
>> This is the code:
>> var popups = new
>> OpenLayers.Control.SelectFeature([gdacs_earth,gdacs_cyclones,gdacs_floods],
>> GeorssPopups.init());
>> map.addControl(popups);
>> popups.activate();
>> GeorssPopups implements the onSelect and onUnselect events.
>> Is still there something wrong in my code?
> It's hard to tell, since there's no information here about the *rest* of
> your code. Can you give a link?
> -- Chris
>> Thanks in advance.
>> Simone
>> View this message in context:
>> http://n2.nabble.com/Popups-on-different-GML-Layers-with-SelectFeature-tp2907685p2907685.html
>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> Christopher Schmidt
> MetaCarta
> Dev mailing list
View this message in context: http://n2.nabble.com/Popups-on-different-GML-Layers-with-SelectFeature-tp2907685p2931244.html
More information about the Dev
