[OpenLayers-Dev] Function createUrlObject not working in IE7
Tim Schaub
tschaub at opengeo.org
Mon May 25 19:03:00 EDT 2009
Eric Lemoine wrote:
> On Sat, May 23, 2009 at 8:48 PM, Debasish Sahu <debasish.sahu at gmail.com> wrote:
>> Hi,
>> The createUrlObject function is not working in IE7.Problem is with the
>> a.host variable.
> Same issue here. Sounds like a regression...
Please add detail to http://trac.openlayers.org/ticket/2060.
The tests are passing for me on IE7. Are they failing for others? Is
something else demonstrating the problem?
Details needed before we can fix properly.
Tim
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
