[OpenLayers-Dev] Function createUrlObject not working in IE7
Debasish Sahu debasish.sahu at gmail.com
Tue May 26 00:09:19 EDT 2009
Tim,
If i run the examples by running it through the file system it works. Moment
I put the examples in apache or tomcat server and access through HTTP URL ,
the example fails.
Thanks
Debasish
On Tue, May 26, 2009 at 4:33 AM, Tim Schaub <tschaub at opengeo.org> wrote:
> Eric Lemoine wrote:
> > On Sat, May 23, 2009 at 8:48 PM, Debasish Sahu <debasish.sahu at gmail.com>
> wrote:
> >> Hi,
> >> The createUrlObject function is not working in IE7.Problem is with the
> >> a.host variable.
> > Same issue here. Sounds like a regression...
> Please add detail to http://trac.openlayers.org/ticket/2060.
> The tests are passing for me on IE7.  Are they failing for others?  Is
> something else demonstrating the problem?
> Details needed before we can fix properly.
> Tim
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Thanks and Warm Regards
Debasish Sahu
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20090526/ee078bed/attachment.html
More information about the Dev mailing list
