[OpenLayers-Dev] Function createUrlObject not working in IE7
Debasish Sahu debasish.sahu at gmail.com
Wed May 27 02:44:11 EDT 2009
Hi Tim,
Here's the error details . Check with IE7 and IE8.
*Message: Invalid argument.
Line: 1378
Char: 5
Code: 0
URI: http://localhost:8080/openlayers/lib/OpenLayers/Util.js
Thanks
Debasish
On Tue, May 26, 2009 at 9:39 AM, Debasish Sahu <debasish.sahu at gmail.com>wrote:
> Tim,
> If i run the examples by running it through the file system it works.
> Moment I put the examples in apache or tomcat server and access through HTTP
> URL , the example fails.
> Thanks
> Debasish
> On Tue, May 26, 2009 at 4:33 AM, Tim Schaub <tschaub at opengeo.org> wrote:
>> Eric Lemoine wrote:
>> > On Sat, May 23, 2009 at 8:48 PM, Debasish Sahu <debasish.sahu at gmail.com>
>> wrote:
>> >> Hi,
>> >> The createUrlObject function is not working in IE7.Problem is with the
>> >> a.host variable.
>> > Same issue here. Sounds like a regression...
>> Please add detail to http://trac.openlayers.org/ticket/2060.
>> The tests are passing for me on IE7.  Are they failing for others?  Is
>> something else demonstrating the problem?
>> Details needed before we can fix properly.
>> Tim
>> Tim Schaub
>> OpenGeo - http://opengeo.org
>> Expert service straight from the developers.
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> Thanks and Warm Regards
> Debasish Sahu
Debasish Sahu
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20090527/3cd77865/attachment.html
More information about the Dev mailing list
