[OpenLayers-Dev] Google and wms shift using mapfish
Simo D simone.dalmasso at gmail.com
Thu May 28 07:21:38 EDT 2009
Hi list, I' built an application which uses mapfish. The problem is that when
i change the base layer from a common WMS to google maps a small shift
appears(the background changes is position). If I resize the window all goes
right. I tried to use the geo ext mapPanel instead of the mapcomponent and
also a map.updateSize() triggered by a layerchange event but unfortunately
without results. All the layers have the sphericalMercator set to true.
If I remove mapfish and use only openlayers all works fine, so the problem
is due to Ext, I think.
Have you got any suggestions?
Thanks in advance.
Simone.
View this message in context: http://n2.nabble.com/Google-and-wms-shift-using-mapfish-tp2987048p2987048.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
