[OpenLayers-Dev] Google and wms shift using mapfish
Eric Lemoine
eric.lemoine at camptocamp.com
Thu May 28 18:10:42 EDT 2009
On Thursday, May 28, 2009, Simo D <simone.dalmasso at gmail.com> wrote:
> Hi list, I' built an application which uses mapfish. The problem is that when
> i change the base layer from a common WMS to google maps a small shift
> appears(the background changes is position). If I resize the window all goes
> right. I tried to use the geo ext mapPanel instead of the mapcomponent and
> also a map.updateSize() triggered by a layerchange event but unfortunately
> without results. All the layers have the sphericalMercator set to true.
> If I remove mapfish and use only openlayers all works fine, so the problem
> is due to Ext, I think.
> Have you got any suggestions?
There indeed still are issues with the map panel and Google layers.
We're working on them. This is a GeoExt discussion, so please continue
the discussion to the GeoExt list.
Cheers,
> Thanks in advance.
> Simone.
> View this message in context: http://n2.nabble.com/Google-and-wms-shift-using-mapfish-tp2987048p2987048.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev
