[OpenLayers-Dev] OpenLayers map.AfterDraw event
geojoe
jwolter at wisc.edu
Fri Nov 6 09:19:55 EST 2009
Christopher,
Thanks for the link.
As to my other problem - I also save the zoom level on the "moveend" event
and call "map.zoomTo(zoomLevel);" at the end of the map Init() function.
This seems to have solved the problem.
Thanks again Christopher and Andreas for helping an infant in OpenLayers.
Joe
Christopher Schmidt-2 wrote:
> On Fri, Nov 06, 2009 at 05:05:43AM -0800, geojoe wrote:
>> Andreas,
>> This seems to work except when I refresh the page I get the extent of the
>> map before the current extent.
>> Is there another event that fires after the map draw that I could use?
>> I just started delving into OpenLayers this week. Where can I find a
>> list
>> of all of the map events like "moveend"? I haven't been able to find
>> them
>> in one place @
>> http://dev.openlayers.org/docs/files/OpenLayers/Map-js.html
> http://dev.openlayers.org/docs/files/OpenLayers/Map-js.html#OpenLayers.Map.EVENT_TYPES
>> Thanks,
>> Joe
>> View this message in context:
>> http://n2.nabble.com/OpenLayers-map-AfterDraw-event-tp3955274p3958625.html
>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> Christopher Schmidt
> MetaCarta
> Dev mailing list
View this message in context: http://n2.nabble.com/OpenLayers-map-AfterDraw-event-tp3955274p3959001.html
More information about the Dev
