[OpenLayers-Dev] OpenLayers map.AfterDraw event
geojoe
jwolter at wisc.edu
Fri Nov 6 15:12:56 EST 2009
The logic I used for the page refresh didn't really work.
It seems that when I use the saved extent in the map Init() function and
call "map.zoomToExtent( lastExtent );" this redraws the last extent properly
but I can no longer zoom out. This command seems to reset the map maxExtent
so when I ZoomToMaxExtent() I'm stuck with the current extent.
I am updating a postgres database by adding or moving points and displaying
two views into that database. I've been trying to display the new data by
doing an HTML page refresh preserving the last extent.
What I would really like is to have a redraw map control that re-reads the
database views to get the updated positions and refreshes the map using the
current extent.
Does a refresh or redraw map control exist that does this? Again, I haven't
been able to find one.
Thanks,
Joe
geojoe wrote:
> Christopher,
> Thanks for the link.
> As to my other problem - I also save the zoom level on the "moveend" event
> and call "map.zoomTo(zoomLevel);" at the end of the map Init() function.
> This seems to have solved the problem.
> Thanks again Christopher and Andreas for helping an infant in OpenLayers.
> Joe
> Christopher Schmidt-2 wrote:
>> On Fri, Nov 06, 2009 at 05:05:43AM -0800, geojoe wrote:
>>> Andreas,
>>> This seems to work except when I refresh the page I get the extent of
>>> the
>>> map before the current extent.
>>> Is there another event that fires after the map draw that I could use?
>>> I just started delving into OpenLayers this week. Where can I find a
>>> list
>>> of all of the map events like "moveend"? I haven't been able to find
>>> them
>>> in one place @
>>> http://dev.openlayers.org/docs/files/OpenLayers/Map-js.html
>> http://dev.openlayers.org/docs/files/OpenLayers/Map-js.html#OpenLayers.Map.EVENT_TYPES
>>> Thanks,
>>> Joe
>>> View this message in context:
>>> http://n2.nabble.com/OpenLayers-map-AfterDraw-event-tp3955274p3958625.html
>>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
>> Christopher Schmidt
>> MetaCarta
>> Dev mailing list
View this message in context: http://n2.nabble.com/OpenLayers-map-AfterDraw-event-tp3955274p3961041.html
More information about the Dev
