[OpenLayers-Dev] [Fwd: [OpenLayers-Trac] [OpenLayers] #2344: label
offset not working as documented]
Roald de Wit
roald.dewit at lisasoft.com
Sun Nov 8 06:39:43 EST 2009
Hi list,
The ticket below made me wonder what david was referring to. The API
documentation on the site points (correctly) to our 2.8 release and not
trunk, so that (most probably) could not be it. I think he referred to
the examples, which use trunk.
Would it make sense having the examples link on the home page point to
the latest stable release as well? This could avoid some confusion.
Regards, Roald
-------- Original Message --------
Subject: [OpenLayers-Trac] [OpenLayers] #2344: label offset not working
as documented
Date: Sun, 8 Nov 2009 08:59:41 +1030
Reply-To: dev at openlayers.org <dev at openlayers.org>
CC: trac at openlayers.org <trac at openlayers.org>
#2344: label offset not working as documented
Reporter: david | Owner:
Type: feature | Status: new
Priority: minor | Milestone: 2.9 Release
Component: general | Version: 2.8
Keywords: | State:
Offset doesn't work on the current release. Downloaded latest SVN and it
works. Suggest that documentation should not advance faster than the
software.
Ticket URL: <http://trac.openlayers.org/ticket/2344>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
Trac mailing list
Trac at openlayers.org
http://openlayers.org/mailman/listinfo/trac
More information about the Dev
