[OpenLayers-Dev] [Fwd: [OpenLayers-Trac] [OpenLayers] #2344: label offset not working as documented]
Andreas Hocevar ahocevar at opengeo.org
Sun Nov 8 11:44:20 EST 2009
very good catch Roald. I think you are absolutely right.
+1 for splitting examples into a release and a trunk version.
Regards,
Andreas.
Roald de Wit wrote:
> Hi list,
> The ticket below made me wonder what david was referring to. The API
> documentation on the site points (correctly) to our 2.8 release and not
> trunk, so that (most probably) could not be it. I think he referred to
> the examples, which use trunk.
> Would it make sense having the examples link on the home page point to
> the latest stable release as well? This could avoid some confusion.
> Regards, Roald
> -------- Original Message --------
> Subject: 	[OpenLayers-Trac] [OpenLayers] #2344: label offset not working
> as documented
> Date: 	Sun, 8 Nov 2009 08:59:41 +1030
> From: 	OpenLayers <trac-20090302 at openlayers.org>
> Reply-To: 	dev at openlayers.org <dev at openlayers.org>
> CC: 	trac at openlayers.org <trac at openlayers.org>
>  Reporter:  david    |       Owner:
>      Type:  feature  |      Status:  new
>  Priority:  minor    |   Milestone:  2.9 Release
> Component:  general  |     Version:  2.8
>  Keywords:           |       State:
>  Offset doesn't work on the current release. Downloaded latest SVN and it
>  works. Suggest that documentation should not advance faster than the
>  software.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev mailing list
