[OpenLayers-Dev] [Fwd: [OpenLayers-Trac] [OpenLayers] #2344:
label offset not working as documented]
Roald de Wit
roald.dewit at lisasoft.com
Sun Nov 8 16:23:41 EST 2009
Christopher Schmidt wrote:
> On Sun, Nov 08, 2009 at 05:44:20PM +0100, Andreas Hocevar wrote:
>> Hi,
>> very good catch Roald. I think you are absolutely right.
>> +1 for splitting examples into a release and a trunk version.
> Released:
> http://dev.openlayers.org/releases/OpenLayers-2.8/examples/lite.html
> http://dev.openlayers.org/releases/OpenLayers-2.8/doc/apidocs/files/OpenLayers-js.html
> Trunk:
> http://openlayers.org/dev/examples/lite.html
> http://dev.openlayers.org/apidocs/files/OpenLayers-js.html
Thanks Chris for the swift action! There are a few more things needed to
be done though:
- change link from homepage to the released examples:
- make sure that example-list is added as a DirectoryIndex (or point
directly to example-list.html)
- add example-list.js (is missing now) to make the example-list.html work
- maybe a more consistent path for both the docs and the examples for
trunk (like both dev.openlayers.org/..)? They're quite different now.
(icing on the cake)
Regards and thanks,
Roald
> -- Chris
>> Regards,
>> Andreas.
>> Roald de Wit wrote:
>>> Hi list,
>>> The ticket below made me wonder what david was referring to. The API
>>> documentation on the site points (correctly) to our 2.8 release and not
>>> trunk, so that (most probably) could not be it. I think he referred to
>>> the examples, which use trunk.
>>> Would it make sense having the examples link on the home page point to
>>> the latest stable release as well? This could avoid some confusion.
>>> Regards, Roald
>>> -------- Original Message --------
>>> Subject: [OpenLayers-Trac] [OpenLayers] #2344: label offset not working
>>> as documented
>>> Date: Sun, 8 Nov 2009 08:59:41 +1030
>>> From: OpenLayers <trac-20090302 at openlayers.org>
>>> Reply-To: dev at openlayers.org <dev at openlayers.org>
>>> CC: trac at openlayers.org <trac at openlayers.org>
>>> #2344: label offset not working as documented
>>> Reporter: david | Owner:
>>> Type: feature | Status: new
>>> Priority: minor | Milestone: 2.9 Release
>>> Component: general | Version: 2.8
>>> Keywords: | State:
>>> Offset doesn't work on the current release. Downloaded latest SVN and it
>>> works. Suggest that documentation should not advance faster than the
>>> software.
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
