[OpenLayers-Dev] [Fwd: [OpenLayers-Trac] [OpenLayers] #2344: label offset not working as documented]
Christopher Schmidt crschmidt at metacarta.com
Tue Nov 10 07:46:20 EST 2009
On Tue, Nov 10, 2009 at 08:50:52PM +1000, Tim Schaub wrote:
> Regarding links from the homepage, I think this deserves a separate
> subject line at least.
For the record, the links that we have been talking about have been the
in-body links, which (from what I can tell) you're not specifically
addressing with your other proposal for changing navigation links. Did
you have other thoughts on what to do with the body (or maybe I'm just
blind)?
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
