[OpenLayers-Dev] multi projections example
Eric Lemoine eric.lemoine at camptocamp.com
Tue Nov 10 10:03:06 EST 2009
Hello
I've written an example showing how to switch the map to another
projection, see the attached HTML file. The example is based on a
pretty simple custom control that exposes a switchTo(projCode) method.
As there have been people asking how to do that with OpenLayers I was
thinking of committing this example into the OpenLayers examples
directory. It could also serve as a base of discussion between people
needing that functionality. But as the example is a bit hackish
(specifically, it uses the private Layer.initResolution method for
resetting the layers), I thought I would ask how people feel about
that before actually committing the example. So any objection in
seeing this example in the OpenLayers' examples dir?
Thanks,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20091110/1bad791b/multi-projections.html
More information about the Dev mailing list
