[OpenLayers-Dev] multi projections example
bartvde at osgis.nl
bartvde at osgis.nl
Tue Nov 10 10:08:54 EST 2009
Hi Eric,
as you know I am very much interested in such functionality as well, and I
have my own hackish implementation right now.
Are you able to show the example in a sandbox?
I would be interested in discussing how we can properly fit reprojection
of an existing map object into OpenLayers.
Best regards,
Bart
> Hello
> I've written an example showing how to switch the map to another
> projection, see the attached HTML file. The example is based on a
> pretty simple custom control that exposes a switchTo(projCode) method.
> As there have been people asking how to do that with OpenLayers I was
> thinking of committing this example into the OpenLayers examples
> directory. It could also serve as a base of discussion between people
> needing that functionality. But as the example is a bit hackish
> (specifically, it uses the private Layer.initResolution method for
> resetting the layers), I thought I would ask how people feel about
> that before actually committing the example. So any objection in
> seeing this example in the OpenLayers' examples dir?
> Thanks,
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
