[OpenLayers-Dev] google map with OpenLayers in IE6
bis_internet fen.luo at isb-ag.de
Thu Nov 19 04:23:45 EST 2009
I would like to show google map as a background map with OpenLayers in IE 6.
The example http://openlayers.org/dev/examples/google.html can only show in
IE unless one connects the local OpenLayers.js but not the remote one.
The problem now is that the map will be slower if the map is updated several
times. When you close the IE window and reopen, then it is initially normal,
and after a few updates again slowly. Nothing changes when you delete the
caches. In Firefox, it works without problems. Somebody has an idea what it
is. Thx!
View this message in context: http://n2.nabble.com/google-map-with-OpenLayers-in-IE6-tp4030845p4030845.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
