[OpenLayers-Dev] WMS POST example
    Andreas Hocevar
    ahocevar at opengeo.org
    Mon Nov 23 15:20:41 EST 2009
bartvde at osgis.nl wrote:
> Hi list,
> about the above example, should we not encourage people to write out SLD
> using OpenLayers.Format.SLD instead?
At least we could.
> Or is there a specific reason why the example uses strings?
Just that the contributor of the patch felt more comfortable doing it
this way (probably because he had the SLD already).
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
