[OpenLayers-Dev] WMS POST example
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Nov 23 17:40:26 EST 2009
Andreas Hocevar wrote:
> bartvde at osgis.nl wrote:
>> Hi list,
>> about the above example, should we not encourage people to write out SLD
>> using OpenLayers.Format.SLD instead?
> At least we could.
>> Or is there a specific reason why the example uses strings?
> Just that the contributor of the patch felt more comfortable doing it
> this way (probably because he had the SLD already).
> Regards,
> Andreas.
Bart,
I would love to see some additional examples for using SLD and
generating SLD from say a form or whatever might be appropriate. I'm
getting pushed to use more OGC compatible formats and I think it would
help a lot to see some better use cases in OL.
Thanks,
-Steve W
More information about the Dev
