[OpenLayers-Dev] Creating shadowed or stroked and filled lines
fredarters
fredarters at gmail.com
Mon Nov 23 16:40:33 EST 2009
I am drawing lines on openlayers for a project. Using a prior map client I
would draw a line with a 1px black border around a 2px colored line using a
stroke and fill values.
However, in openlayers the fill values for the style of a line are only used
for polygons, not lines. I attempted to achieve the same effect by drawing
two separate lines on the same path, a black line 4px wide and a color line
2px wide. For some reason, only the 2px color line shows up on the map. If
I pause the rendering between the two lines, they both render but as soon as
I zoom or pan the map the first (4px black) line dissapears and only the
second 2px color line remains rendered.
Any idea why that might be happening or have a better idea how to achieve
that effect?
I am doing something like this:
// first line
var lineBg = new OpenLayers.Geometry.LineString(points);
var theStyleBg = {
strokeColor: '#000000',
strokeWidth: 4,
strokeLinecap: 'round'
var featureBg = new OpenLayers.Feature.Vector(lineBg, null,
theStyleBg);
featureBg.id = 'linebg';
this.pathLayer.addFeatures([featurebg]);
// second line
var line = new OpenLayers.Geometry.LineString(points);
var theStyle = {
strokeColor: '#eedd00',
strokeWidth: 2,
var feature = new OpenLayers.Feature.Vector(line, null, theStyle);
feature.id = 'line';
this.pathLayer.addFeatures([feature]);
View this message in context: http://n2.nabble.com/Creating-shadowed-or-stroked-and-filled-lines-tp4054199p4054199.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
