[OpenLayers-Dev] dinamic size with ext3.0
Andreas Hocevar
ahocevar at opengeo.org
Mon Nov 30 04:56:48 EST 2009
Luca Santaniello wrote:
> Hi,
> I want resize map automatically but I have a problem. I use ext3. I
> have one panel and I want render my map into this panel to max extent.
Create your map, or at least call map.updateSize() in a function
registered for your panel's afterrender method.
Also, you may want to try GeoExt (http://geoext.org), which provides a
MapPanel that does exactly what you are requesting here.
Regards,
Andreas.
> Can help me please?
> Thanks
> Luca
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
