[OpenLayers-Dev] dinamic size with ext3.0
Rodolfo Barriga
rodolfo.barriga at gmail.com
Mon Nov 30 07:40:13 EST 2009
maybe something like this could help you:
var p = new Ext.Panel({
region: 'center',
html: '<div id="map" style="width:100%; height:100%;" />'
you can init the OL map in that Div
var map = new OpenLayers.Map('map', options);
then you can update map size with the extjs panel resize event.
(http://www.extjs.com/deploy/dev/docs/?class=Ext.Panel EXTJS Panel API
reference.)
p.on('resize', function() {
mapObjet.updateSize();
Greetings Rodolfo B
2009/11/30 Luca Santaniello <lsantaniello at cidsoftware.it>
> Hi,
> I want resize map automatically but I have a problem. I use ext3. I have
> one panel and I want render my map into this panel to max extent.
> Can help me please?
> Thanks
> Luca
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20091130/bdcca79e/attachment.html
More information about the Dev
