[OpenLayers-Dev] tinyows and OL WFS Filters using PropertyIsLike
Paul Spencer
pspencer at dmsolutions.ca
Tue Oct 6 21:53:29 EDT 2009
I have discovered that in the tinyows schema, it has escape for v1 and
escapeChar for v1_1_0 so I am going to go ahead and prepare a patch
based on option 2 below by adding PropertyIsLike to the v1_1_0 code.
If this ends up being wrong, we can discuss it in the ticket that I
will create for the patch.
Cheers
Paul
On 2009-10-06, at 5:21 PM, Paul Spencer wrote:
> Hey WFS gurus ... I am using OL with a WFS layer against tinyows with
> a layer filter using PropertyIsLike and tinyows is coughing up a lung
> because the filter is not passing schema validation. Looking into
> this further, it seems that tinyows' schema is expecting an attribute
> called escapeChar but OL is passing an attribute called escape. I've
> made it work by hacking OpenLayers.Format.Filter.v1 writers to put
> escapeChar in the output but I am wondering what the right fix is:
> 1) is escapeChar the right attribute name in v1, in which case both
> the reader and writer for PropertyIsLike should be changed?
> 2) is escape the right attribute in v1 and escapeChar in v1_1_0, in
> which case the reader and writer needs overrides for PropertyIsLike in
> v1_1_0?
> 3) is escape the right attribute in both versions and tinyows is
> wrong?
> If there is a change needed in OpenLayers, I'll do the patch if
> someone tells me what the right answer is :)
> Cheers
> Paul
> __________________________________________
> Paul Spencer
> Chief Technology Officer
> DM Solutions Group Inc
> http://research.dmsolutions.ca/
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Paul Spencer
More information about the Dev
