[OpenLayers-Dev] GeoWebCache and fractionalZoom: addin or feature proposal
Marc Jansen jansen at terrestris.de
Thu Oct 8 16:26:37 EDT 2009
Hi devs,
we develop an OpenLayers application that uses WMS-tiles generated by
GeoWebCache. But we have the need to allow fractionalZoom as well,
because the application will sometimes zoom to non-integer scales (when
we highlight search results, for instance). Without a change to the code
of OpenLayers these fractional zoomlevels mess up the map (because right
now GeoWebCache does not act as WMS when being asked for tiles it cannot
provide).
For the application in question we patched OpenLayers/Layer/WMS.js to
have an option to use a different baseURL when fractional zoomlevels are
needed. So when map.zoom is non-integer, we ask the original WMS-Server
for slow but correct tiles.
I am not sure whether this is possibly a addin, or an additional option
for WMS-layers. What do you think?
The code in question would introduce a new property
"alternativeFractionalZoomURL" (name of course TBD) to
OpenLayers.Layer.WMS-objects and one additional check in the
WMS.getURL-method (if the map allows fractional zoomlevels AND if the
alternativeFractionalZoomURL is not empty AND the current map.zoom is
fractional THEN use the altURL, behave as always in any other case).
Does this break code elsewhere? We did not have the time to run the
tests up until now, but maybe you see problems early at this stage.
Regards and thanks for any comments,
Marc
BTW: the new WMS.Post layer looks really promising! Great work!
More information about the Dev mailing list
