[OpenLayers-Dev] tinyows and OL WFS Filters using PropertyIsLike
Paul Spencer
pspencer at dmsolutions.ca
Thu Oct 8 13:09:36 EDT 2009
Thanks Tim, that looks like a more thorough patch than the one I was
envisioning - probably better that you did it :) I will test soonish,
I need to apply it to an older version of OL that I am using in a
specific project but I had made essentially the same changes manually
so I assume it will work.
Cheers
Paul
On 2009-10-08, at 12:24 PM, Tim Schaub wrote:
> Hey Paul-
> See if the patch for #2301 does the trick for you.
> http://trac.openlayers.org/ticket/2301
> Tim
> Tim Schaub wrote:
>> Paul Spencer wrote:
>>> I have discovered that in the tinyows schema, it has escape for v1
>>> and
>>> escapeChar for v1_1_0 so I am going to go ahead and prepare a patch
>>> based on option 2 below by adding PropertyIsLike to the v1_1_0 code.
>>> If this ends up being wrong, we can discuss it in the ticket that I
>>> will create for the patch.
>> Glancing at the Filter Encoding specs (1.0.0 and 1.1.0) it looks like
>> there are some typos in the 1.0.0 docs. The prose mentions
>> escapeChar
>> but the examples use escape. When I've pointed out discrepancies
>> like
>> this before, I've been told the schema is the final word.
>> http://schemas.opengis.net/filter/1.0.0/filter.xsd
>> http://schemas.opengis.net/filter/1.1.0/filter.xsd
>> So it is "escape" in 1.0.0 and "escapeChar" in 1.1.0. This should be
>> patched in the filter formats.
>> Tim
>>> Cheers
>>> Paul
>>> On 2009-10-06, at 5:21 PM, Paul Spencer wrote:
>>>> Hey WFS gurus ... I am using OL with a WFS layer against tinyows
>>>> with
>>>> a layer filter using PropertyIsLike and tinyows is coughing up a
>>>> lung
>>>> because the filter is not passing schema validation. Looking into
>>>> this further, it seems that tinyows' schema is expecting an
>>>> attribute
>>>> called escapeChar but OL is passing an attribute called escape.
>>>> I've
>>>> made it work by hacking OpenLayers.Format.Filter.v1 writers to put
>>>> escapeChar in the output but I am wondering what the right fix is:
>>>> 1) is escapeChar the right attribute name in v1, in which case both
>>>> the reader and writer for PropertyIsLike should be changed?
>>>> 2) is escape the right attribute in v1 and escapeChar in v1_1_0, in
>>>> which case the reader and writer needs overrides for
>>>> PropertyIsLike in
>>>> v1_1_0?
>>>> 3) is escape the right attribute in both versions and tinyows is
>>>> wrong?
>>>> If there is a change needed in OpenLayers, I'll do the patch if
>>>> someone tells me what the right answer is :)
>>>> Cheers
>>>> Paul
>>>> __________________________________________
>>>> Paul Spencer
>>>> Chief Technology Officer
>>>> DM Solutions Group Inc
>>>> http://research.dmsolutions.ca/
>>>> _______________________________________________
>>>> Dev mailing list
>>>> Dev at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/dev
>>> Paul Spencer
>>> Dev mailing list
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> Dev mailing list
Paul Spencer
More information about the Dev
