[OpenLayers-Dev] tinyows and OL WFS Filters using PropertyIsLike
Tim Schaub
tschaub at opengeo.org
Thu Oct 8 12:24:19 EDT 2009
Hey Paul-
See if the patch for #2301 does the trick for you.
http://trac.openlayers.org/ticket/2301
Tim
Tim Schaub wrote:
> Paul Spencer wrote:
>> I have discovered that in the tinyows schema, it has escape for v1 and
>> escapeChar for v1_1_0 so I am going to go ahead and prepare a patch
>> based on option 2 below by adding PropertyIsLike to the v1_1_0 code.
>> If this ends up being wrong, we can discuss it in the ticket that I
>> will create for the patch.
> Glancing at the Filter Encoding specs (1.0.0 and 1.1.0) it looks like
> there are some typos in the 1.0.0 docs. The prose mentions escapeChar
> but the examples use escape. When I've pointed out discrepancies like
> this before, I've been told the schema is the final word.
> http://schemas.opengis.net/filter/1.0.0/filter.xsd
> http://schemas.opengis.net/filter/1.1.0/filter.xsd
> So it is "escape" in 1.0.0 and "escapeChar" in 1.1.0. This should be
> patched in the filter formats.
> Tim
>> Cheers
>> Paul
>> On 2009-10-06, at 5:21 PM, Paul Spencer wrote:
>>> Hey WFS gurus ... I am using OL with a WFS layer against tinyows with
>>> a layer filter using PropertyIsLike and tinyows is coughing up a lung
>>> because the filter is not passing schema validation. Looking into
>>> this further, it seems that tinyows' schema is expecting an attribute
>>> called escapeChar but OL is passing an attribute called escape. I've
>>> made it work by hacking OpenLayers.Format.Filter.v1 writers to put
>>> escapeChar in the output but I am wondering what the right fix is:
>>> 1) is escapeChar the right attribute name in v1, in which case both
>>> the reader and writer for PropertyIsLike should be changed?
>>> 2) is escape the right attribute in v1 and escapeChar in v1_1_0, in
>>> which case the reader and writer needs overrides for PropertyIsLike in
>>> v1_1_0?
>>> 3) is escape the right attribute in both versions and tinyows is
>>> wrong?
>>> If there is a change needed in OpenLayers, I'll do the patch if
>>> someone tells me what the right answer is :)
>>> Cheers
>>> Paul
>>> __________________________________________
>>> Paul Spencer
>>> Chief Technology Officer
>>> DM Solutions Group Inc
>>> http://research.dmsolutions.ca/
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
>> Paul Spencer
>> Dev mailing list
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
