[OpenLayers-Dev] [itr@pointcarbon.com: [OpenLayers-Trac] Error in
	Marker.js]
    Christopher Schmidt
    crschmidt at metacarta.com
    Mon Oct 26 12:47:36 EDT 2009
Sent to the wrong list.
----- Forwarded message from Ian Trotter <itr at pointcarbon.com> -----
To: "trac at openlayers.org" <trac at openlayers.org>
Date: Mon, 26 Oct 2009 17:31:12 +0100
Subject: [OpenLayers-Trac] Error in Marker.js
Reply-To: dev at openlayers.org
The resolution of http://trac.openlayers.org/ticket/2258 seems to have introduced a bug with the event-handling for markers. It seems that the Marker.events property is no longer being set when a marker is initialised.
As an example, you can see that http://openlayers.org/dev/examples/georss-markers.html no longer shows the markers, with an error message that marker.events is null.
- Ian
Trac mailing list
Trac at openlayers.org
http://openlayers.org/mailman/listinfo/trac
----- End forwarded message -----
Christopher Schmidt
MetaCarta
More information about the Dev
